Source of RFI in console?
K4RBT
The 12 volt to usb converters use a switching buck regulator. A good one will be properly bypassed, a cheap one, do not bet on it. These things produce square waves, rich in harmonics. I had one that produced signals up to 180MHz, its nice to have a spectrum analyzer, made a chain saw sound in the radio. I have replaced all I can, even the Apple ones as I trust none that are made in China.
Since you have found the problem, this suggestion is too late, but to test the antenna feed line, I use a NMO to SO239 adapter ,usually to put a watt meter at the antenna base, or a load to simulate the antenna.
