Source / Radio ID changes when Unit changes TG - TXWARN
n5pwp
Spring, Texas
I had the idea (apparently mistaken) that Source or RIDs stayed constant through out the TXWARN system. I heard Life Flight #3 talking to HC MA 2. The RID on TG 537 doesn't match its RID on TG 1369. Do the RIDs change when they communicate on different TGs?
Mike
Reconrider
Trx-1 or Sds100
Between the lines
Are you sure it's not multiple radios?
Radios programmed to a trunk system don't change unless the sysadmin changes them.
KevinC
Moderator
Super Moderator
Somewhere other than home :(
Mike
Each helicopter has multiple radiios.
n5pwp
Spring, Texas
OK, well multiple radios would explain it. I guess they would have to setup a patch ahead of time to cross TGs? Thanks, guys. simplest answer is usually the correct one. Its funny that it was one digit off on TG 537 from its RID on TG 1369. I got it logged in my DSDPlus Radios file.
Mike
