South Bay Regional Public Communications - Narrowband/new channels – April 30th
LAflyer
Global DB Admin
Moderator
SoCal
The SBRPCA will be narrowbanding on April 30th. Along with this there will be new channel line up and naming convention, most frequencies will become DPL, and while 3 new tac frequencies will be formally rolled out also.
The tentative planned channel line up will be as follows:
Channel – Frequency – Tone - Description
1 – 470.6375 – 131DPL – Manhattan & Hermosa Beach PD Dispatch
2 – 470.3875 – 245DPL – Hawthorne PD Dispatch
3 – 470.0125 – 371DPL – Gardena PD Dispatch
4 – 471.3375 – 85.4PL – El Segundo PD Dispatch
5 – 506.0125 – 156DPL – Fire Dispatch
6 – 506.0375 – 261DPL – Fire Dispatch Alternate/Command
7 – 472.5375 – 103.5PL – El Segundo Fire Tac
8 – 471.1125 – 411DPL – Tac 4
9 – 470.3125 – 532DPL – Tac 5
10- 470.0375 – 654DPL – Tac 6
11– 470.8125 – 331DPL – Tac 7
12– 506.5250 – 731DPL – Tac 8 – mobile only
13– 506.5500 - 465DPL – Tac 9 – mobile only
14– 506.6750 – 754DPL – Tac 10 – mobile only
15– 470.1875 – 516DPL – Hermosa Beach PD Dispatch weekends/special events
16– 482.4250 – 79.7PL – Fire RIC – mobile only (frequency shared with Torrance).
Note – the Tac's may now be utilized by both police & fire.
I'll get the Db updated accordingly.
LAflyer
Global DB Admin
Moderator
SoCal
Don't forget this is planned for the coming weekend.
Db has been updated to reflect the above changes.
LAflyer
Global DB Admin
Moderator
SoCal
Sounds like they are still using the old PLs. Anyone know what happened?
I did notice however they have had an open carrier on two of the Tacs intermittently, so maybe they are working on things.
LAflyer
Global DB Admin
Moderator
SoCal
Seems some changes might have occurred as one unit yesterday had a hard time finding Tac-6.
I've also heard an intermittent open carrier on what will be the Gardena dispatch channel.
LAflyer
Global DB Admin
Moderator
SoCal
Due to multiple technical issues sounds like the delayed narrow banding will finally take place by late October.
LAflyer
Global DB Admin
Moderator
SoCal
The switch over took place last night. Now utilizing new DPLs and channel line up.
LAflyer
Global DB Admin
Moderator
SoCal
I believe 470.0125 is technically the Gardena PD channel, however due to ongoing open carrier on 470.0125 its using one of the Tac's for dispatching.
I have not seen a note yet that the channels have formally been swapped.
