south Dakota trs
gator
Mitchell,SD
can not seem to download south dakota trs into unitrunker.I have put in all the the system id and my user name and password but nothing seems to happen.
Is it this one? If so ... looks like an XML parsing issue with an undefined entity. That's a fancy way of saying, it doesn't like parsing the "&deg;" fragment buried somewhere in the text. Someone was trying to indicate degrees of latitude and longitude with the degree symbol. I think the only entities guaranteed to be built-in are (&) &amp; (<) &lt; (>) &gt; (") &quot; and &nbsp; ...
You can verify issues like this by opening the TEMP.XML file in Internet Explorer. It will identify the source line where the document failed as valid XML. I don't have a work-around for this at the moment.
gator
Mitchell,SD
South Dakota TrS
yes that is the one darn I was hoping to do this hope that can be fixed.
thanks
I'll ask the database admin to edit one of the sites. Here's the culprit ...
<site num="041" desc="Watertown" callsign="Special" county="Codington" location="44&deg;52\'12.89\&quot;N 97&deg; 6\'35.89\&quot;W" neigh="8,13,16,21,34,39,40" ct="105.88" modulation="AP-25">
Technically, that's not valid unless "deg" is defined. It's an XML thing.
-rick
gator
Mitchell,SD
South Dakota TrS
I see some changes have been made to the Watertown site in the database but I am still unable to download anything.
I was able to successfully pull down the file. You should have seven files with names starting with MOTO880A. The GID / groups data file is about 57k. Were you monitoring the system while downloading the data? You can do so but it is not required for downloading.
Edit: seems the DB admins fixed some but not all of the funky text. They cleaned the rest on a second pass. By the time I checked, everything was fine.
gator
Mitchell,SD
South Dakota TrS
ok ,
yes I have those files but how do I get them to ruin the program.I have no band plan do I need to enter that myself or was that part of the download.I have other questions but I will start with this one.
The program created a bandplan when the system was downloaded. However, looking at the resulting data - it didn't parse correctly so you'll have to edit it. You can do so from within the program or exit the program and edit the PLN file from a text editor like NOTEPAD.
Each site has it's own bandplan. This system has a lot of sites - so there's a lot of bandplans to update. You may want to do this grunt work in NOTEPAD.
The first column is the site number. The other columns are min, max, base and step size. Here's the incorrect data.
Code:
1,454,0,157,15
1,436,0,157,12
1,380,0,155,15
It should look something like ...
Code:
1,380,435,155415000,15000
1,436,453,157200000,12500
1,453,759,157470000,15000
The above takes care of site 1. You would have to copy / paste the same three lines - replacing the "1" with the other site numbers. If you only monitor one site, don't bother with the other sites. Update the one you monitor and ignore the rest.
-rick
Sorry folks, that last post wasn't quite right. Try this for the PLN file.
Code:
1,380,453,155415000,15000
1,454,435,157470000,15000
1,436,759,157200000,12500
2,380,453,155415000,15000
2,454,435,157470000,15000
2,436,759,157200000,12500
3,380,453,155415000,15000
3,454,435,157470000,15000
3,436,759,157200000,12500
4,380,453,155415000,15000
4,454,435,157470000,15000
4,436,759,157200000,12500
5,380,453,155415000,15000
5,454,435,157470000,15000
5,436,759,157200000,12500
6,380,453,155415000,15000
6,454,435,157470000,15000
6,436,759,157200000,12500
7,380,453,155415000,15000
7,454,435,157470000,15000
7,436,759,157200000,12500
8,380,453,155415000,15000
8,454,435,157470000,15000
8,436,759,157200000,12500
9,380,453,155415000,15000
9,454,435,157470000,15000
9,436,759,157200000,12500
10,380,453,155415000,15000
10,454,435,157470000,15000
10,436,759,157200000,12500
11,380,453,155415000,15000
11,454,435,157470000,15000
11,436,759,157200000,12500
12,380,453,155415000,15000
12,454,435,157470000,15000
12,436,759,157200000,12500
13,380,453,155415000,15000
13,454,435,157470000,15000
13,436,759,157200000,12500
14,380,453,155415000,15000
14,454,435,157470000,15000
14,436,759,157200000,12500
15,380,453,155415000,15000
15,454,435,157470000,15000
15,436,759,157200000,12500
16,380,453,155415000,15000
16,454,435,157470000,15000
16,436,759,157200000,12500
17,380,453,155415000,15000
17,454,435,157470000,15000
17,436,759,157200000,12500
18,380,453,155415000,15000
18,454,435,157470000,15000
18,436,759,157200000,12500
19,380,453,155415000,15000
19,454,435,157470000,15000
19,436,759,157200000,12500
20,380,453,155415000,15000
20,454,435,157470000,15000
20,436,759,157200000,12500
21,380,453,155415000,15000
21,454,435,157470000,15000
21,436,759,157200000,12500
22,380,453,155415000,15000
22,454,435,157470000,15000
22,436,759,157200000,12500
23,380,453,155415000,15000
23,454,435,157470000,15000
23,436,759,157200000,12500
24,380,453,155415000,15000
24,454,435,157470000,15000
24,436,759,157200000,12500
25,380,453,155415000,15000
25,454,435,157470000,15000
25,436,759,157200000,12500
26,380,453,155415000,15000
26,454,435,157470000,15000
26,436,759,157200000,12500
27,380,453,155415000,15000
27,454,435,157470000,15000
27,436,759,157200000,12500
28,380,453,155415000,15000
28,454,435,157470000,15000
28,436,759,157200000,12500
29,380,453,155415000,15000
29,454,435,157470000,15000
29,436,759,157200000,12500
30,380,453,155415000,15000
30,454,435,157470000,15000
30,436,759,157200000,12500
31,380,453,155415000,15000
31,454,435,157470000,15000
31,436,759,157200000,12500
32,380,453,155415000,15000
32,454,435,157470000,15000
32,436,759,157200000,12500
33,380,453,155415000,15000
33,454,435,157470000,15000
33,436,759,157200000,12500
34,380,453,155415000,15000
34,454,435,157470000,15000
34,436,759,157200000,12500
35,380,453,155415000,15000
35,454,435,157470000,15000
35,436,759,157200000,12500
36,380,453,155415000,15000
36,454,435,157470000,15000
36,436,759,157200000,12500
37,380,453,155415000,15000
37,454,435,157470000,15000
37,436,759,157200000,12500
38,380,453,155415000,15000
38,454,435,157470000,15000
38,436,759,157200000,12500
39,380,453,155415000,15000
39,454,435,157470000,15000
39,436,759,157200000,12500
40,380,453,155415000,15000
40,454,435,157470000,15000
40,436,759,157200000,12500
41,380,453,155415000,15000
41,454,435,157470000,15000
41,436,759,157200000,12500
42,380,453,155415000,15000
42,454,435,157470000,15000
42,436,759,157200000,12500
43,380,453,155415000,15000
43,454,435,157470000,15000
43,436,759,157200000,12500
44,380,453,155415000,15000
44,454,435,157470000,15000
44,436,759,157200000,12500
45,380,453,155415000,15000
45,454,435,157470000,15000
45,436,759,157200000,12500
46,380,453,155415000,15000
46,454,435,157470000,15000
46,436,759,157200000,12500
47,380,453,155415000,15000
47,454,435,157470000,15000
47,436,759,157200000,12500
48,380,453,155415000,15000
48,454,435,157470000,15000
48,436,759,157200000,12500
gator
Mitchell,SD
South Dakota TrS
so what is it do I put all the sites in or just the one I am monitoring?
gator
Mitchell,SD
South Dakota TrS
Sorry for being a bug.
My problem now is I put them in the notepad and save it.I go and check it and make sure it is still there and correct but when I start untrunker to see if it made in on the program it only give me one of the band plans.So I check the note pad again and instead of the three there is just one.
tyytor
Wyoming
South Dakota trs
this might be because some sites only need one band plan other will need all three
some just use two it depends on the site.
