Site 02 (937.6875 cc)(Type II) is still on the air.
For the short time I monitored yesterday evening, all talkgroups were TDMA and encrypted. Most were also patched together with other talkgroups.
I was trying to understand the new talkgroup numbering. Just as a pure guess, it looks like they followed the traditional conversion from Motorola Type II to P25 (i.e., divide the old talkgroup by 16), but then they slapped a "1" to the front (same as adding 10000).
For example, OPS 40 would be converted from 32624 on the old system to 12039 on the new system.
32624 / 16 = 2039
2039 + 10000 = 12039
Again, this is purely a guess.
Encrypted? So I'm not going to be able to listen to SCE even with a Phase II scanner?
bcorbin, of the three you mentioned you can hear in the SCV, here in Chatsworth 935.275 comes booming in.....I'd guess this is Oat Mtn...
I can also hear well, though weaker, 936.275
I dont have P25P2 here unfortunately.
This happens when you transition from 3600 to 9600 via SmartX. Take an existing SmartZone system, remove the Zone Controller and upgrade all core infrastructure to a P25 M core, and connect the existing 3600 sites via the SmartX box. From an over-the-air perspective (scanner or radio) you won't even know the difference. Then gradually add true P25 RF sites. Keep in mind you cannot share the same site numbers in the same zone core. Within the system (via the UNC-W web interface) where the infrastructure is defined you create individual RF sites and specify them as one or the other.I was trying to understand the new talkgroup numbering. Just as a pure guess, it looks like they followed the traditional conversion from Motorola Type II to P25 (i.e., divide the old talkgroup by 16), but then they slapped a "1" to the front (same as adding 10000).
Correct. That's the Zone number. As part of the P25 protocol there's always a Zone number transmitted over the air in the control channel stream and the radios always looks for it. With each Zone you can have your own set of site numbers (1-020, 2-020, etc up to 7 zones). Each Zone will have its own "Core" that's responsible for call setup and processing (i.e., its own zone controllers) among many other things.(I believe the database may be appending a 1- to the site number - eg 1-107)
32624 / 16 = 2039
