Southern NH Scanner Stream Test
NYRHKY94
Brunswick County, NC
Hello:
I've set-up a live stream of my BC796D. I'm testing this using the free hosting service on www.streamwebtown.com in conjunction with Windows Media Encoder.
I've set the stream up to screen capture the alpha tags being shown in my Proscan software. The sound is live but there is a 20-30 second real-time delay.
All you need is Windows Media Player installed on your end. When you type the link below into your browser, it should come right up and connect to the display & sound of my scan. Just adjust the size of your Windows Media Player as you like.
Right now I'm scanning the following towns/departments:
-Londonderry Police & Fire
-Derry Police
-Derry Fire Alarm
-Bedford Police
-Pelham Police
-Merrimack County Dispatch
-Rockingham County West
Sometimes the server goes down at streamwebtown.com, but I'll check in
on it regularly and reset it if needed.
http://www.streamwebtown.com/snhscanner
Mike - Londonderry
Thesnowdog
NH thread
Mike-
I have same scanner, and having a diificult time setting up Mass State Police. Do you have this programmed in? and if you do, can you send me step by step process. I've tried everything, even following steps on posted here on the website. I'm not sure where else to go. Any help will do.
Thanks-
Jay
Merrimack Valley
NYRHKY94
Hi Jay:
Are you looking for help with setting up a live stream of your scanner or looking for help with programming State PD into your scanner?
Thanks,
Mike
fd71022004
Feed Comment
Your scanner feed works very well.
Are you planning to have this on more?
If seems to be off now.
Will you be trying to be on 24/7?
Thanks,
John
NYRHKY94
Hi John:
Thanks for the feedback. I'm not likely to have the stream on full-time at this point, but I will try to put it up as often as possible though. I'm running it through an old Dell laptop hooked-up to an external USB sound card.
When it's on, you'll likely hear the same towns/departments I usually listen to in Southern NH (Rockingham County). I do however change up the frequencies now and then.
P.S. I don't leave the scanner on over night, so the stream is usually turned off by 11:00pm.
Thanks - Mike
LPD7
I like your feed alot, i did the same thing, but i had a lot of frequencies, but mabye you could add the Nashua Trunk if you can get it, also Salem and Merrimack PD's would be a good addition. Possibly sdding Some NH State Police, probably Troop A and/or Troop B
