Space Communications
D
DaveNF2G
Guest
Is there enough interest for a forum on space-based communications?
It could cover such things as shuttles, communication satellites, space mission support comms, weather satellites, ham radio satellites, or other space related communications that can be heard on HF receivers or scanners.
I usually argue against new forums that I think would be redundant. This area seems to be relatively uncovered and does not appear to fit neatly into any existing category. I could be wrong. :wink:
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Good idea.
Possible name : Aerospace Radio Discussion Forum
Do we have any NASA people on board in RR.com ?
rdale
Lansing, MI
There's not really much that changes in the space monitoring field though... Shuttle comms are only heard on takeoff and reentry and only if your on the east coast or west coast. All known HF freq's that rebroadcast NASA TV are listed, things are pretty static in that field.
kma371
Not entirely true. I beleive the EVA comms are monitorable as well.
rdale
Lansing, MI
They used to but I thought they changed to a digital connection when they added helmet cams, but you may be correct.
In any case, hardly seems enough traffic in the main forum on sat's to require a new one.
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
I think this is a good suggestion and will consider it. Thanks Dave.
eorange
♦RF Enabled Member♦
Cleveland, OH
I would agree.
Regarding sats - I do a fair amount of sat monitoring (milsats, ISS, conduct amateur sat QSOs), and amsat.org along with the well-established hearsat mailing list has this area covered.
D
DaveNF2G
Guest
So..... which one of those is carried on RadioReference?
Your observation seems irrelevant to a discussion about adding a forum here. Am I missing something?
eorange
♦RF Enabled Member♦
Cleveland, OH
Yes. The hearsat mailing list is a forum that covers satellite comms very well. Many experts contribute there daily. It is the go-to place for that kind of topic.
Conversely, I see little activity on radioreference regarding satellite and space-related topics. So my opinion is such a forum here may not be the best use of limited forum resources.
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
FWIW, it may be because there isn't a location to discuss these types of things here.
I sometimes believe in the phrase "Build it, and they will come"
D
DaveNF2G
Guest
That's what I was thinking.
I'm not going to get into debates or try to "sell" the idea any further. I've made the suggestion and whatever LB decides to do will be fine. If the forum gets added, I'll read it and contribute anything I might find out. If not, then no problem.
W8OSP
Gallia Co Ohio
Well i myself do ALOT of ISS work, packet, voice and what ever else, plus tryin other sats aswell. i do monitor alot of stuff aswell, i think its a great idea!
atwageman
Monroe, NC
I think it would be a great forum addition. I monitor space station comms as well as shuttle and anything the russians send up.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Just to add this - I have constructed a basic SATCOM wiki page which, due to the low volume of links I had (and some came from eorange), combines Amateur sats with some of the military stuff. If there's enough links and interest, that page could be split between the 2 - if someone is willing to sit down and code the links.
The page, as we have it now, can be found here...
http://wiki.radioreference.com/index.php/SATCOM
If a forum is indeed opened up on this subject, we should put this link into a sticky.
73s Mike
