dickie757
Wired
27 October 0815 Eastern time is the start of a test session for slow scan TV from ISS.
145.8MHz PD120 coding
There is an EVA on the 30th, so the test session will pause then.
Good luck!
Go to upper right corner to adjust for your particular location. Dont make the mistake I made one event and look at the passes for NOT your radio location. I was bummed when I thought there were no passes during the event, but actually, there was, but I did not have MY location set.
This page is set for my general location....change it!!
Verification test - Oct 27-Nov 1
The SSTV system in the Service Module will again attempt to verify a replacement piece of hardware during the period of Oct 27 until Nov ...
ariss-sstv.blogspot.com
Good luck!
ISS - Visible Passes
Satellite predictions and other astronomical data customised for your location.
heavens-above.com
