Speaker hum
mrmann901
TN
Will Uniden repair a hum coming from speaker on my SDS200? It happens when connected to extermal speaker also. Is this expensive to fix? I don't want to trt it myself.
enosjones
Price, Utah
Some of them hum on their own without an external speaker, I believe they will fix it if its humming on their own, not sure on the external one unless the jack your plugging it into is causing it. They may replace the jack perhaps
mrmann901
TN
It hums through the internal speaker the same as the external one.
JoeBearcat
Uniden Representative
Yeah then they'll fix it , mine does some too I just haven't sent it in yet
Last I knew their fix is not exactly the fix I proposed to production, but it is electrically nearly identical and should cure the hum.
They may have changed their fix in the last couple years to match production.
Skypilot007
Medford, NJ
Would it be possible to know what is causing the hum and what the fix is?
RandyKuff
Lorain, Ohio
Display board is not grounded correctly with the main board...
I did the fix myself...
