prescottmatthew
I have a TRX-1 that is not muting the speaker when I insert headphones into the jack. Am I missing a setting in the EZ-Scan PC software? If not a setting, is there a known solution to this problem?
I'm CPU, DSP, and PC software updated as of 7/31/17. In EZ-Scan, under the general settings tab, volume settings, I've tried muting the speaker and setting headphone volume up in all my V-scanner folders. After copying the configuration to the scanner, it's behaving exactly the same way. Other setting changes do work (e.g. key beep and creating a new V-folder).
Any advice would be tremendously appreciated. Thank you.
