Uniden are still selling thousands, of 396XT and 996XT's around the globe.
People shouldn't forget that the x36HP scanners were basically designed to cater only for the North American and Canadian markets. Outside of that target market there is a whole global market for 'traditional' P25/digital and analogue scanners.
The x96XT scanners are probably overdue for a facelift and an update. Most people that own a 396xt for example are pretty happy with the size and overall layout, but an updated 396xt with the following updates would serve Uniden well both globally and within the home markets IMHO:
Updated 396xt changes:
* Retain a form factor close to the existing unit's size (the 436HP is too big to EDC IMHO).
* Larger display with large, medium and small fonts options for those who want less or more detail.
If you look at the black surround around the existing 396xt LCD, there is sufficient space there to potentially increase the LCD size up to 40mm x 30mm or even larger.
* Retain the 25-1300Mhz coverage.
* Change the volume control to default to volume (unless pressed for squelch)
* Incorporate Phase 2 and DMR.
* Incorporate real NFM filtering (add NFM IF filter)
* Incorporate limited internal memory or an SD card for audio recording/logging (if Uniden can sort out the SD crash problems).
* Incorporate illuminated keypad buttons (doesn't need to be bright, just bright enough to see in the dark. with time delay).
* Get rid of the dated silver front panel.
* Faster USB interface plug.
* Combined Discriminator/Control channel data output.
As for the 996xt, many of these updates could be adapted to that model too.
Most of these changes would require significant hardware re-designs, but some aspects of the existing design could be retained with minor re-tooling, such as the case and front end filtering etc.
The biggest issue for Uniden, and I'm sure they are well aware of this, is that if they did release such a product, sales of the x36HP would likely plummet.
It would be a tough decision for Uniden. Hold off on releasing an updated XT series scanner in the hope that the x36HP will eventually pay for itself in four or five years time, or release an updated XT scanner now and potentially sell thousands more units at home and around the Globe.
