VY2RWM
VY2RWM
Does anyone have specifications for sds200. In particular what is the sensitivity on VHF, UHF frequencies? Thanks in advance.
Cannot find any specs no matter what I google. Even called Uniden. Specs are not published. Only answer specific questions via request to head office. I find it incomprehensible that a manufacturer wouldn't publish specs. I am trying to work out a link budget which requires receiverGoogle for the spec sheet. You might want to look at two items, sensitivity and selectivity. They are listed for each band. I always confused these two specs When I compared scanner receivers ability to hear...
.Does anyone have specifications for sds200. In particular what is the sensitivity on VHF, UHF frequencies? Thanks in advance.
Thanks very much. Hopefully they will apply. Why publish only in European version? Makes no sense. But the world becomes curiouser and curiouser. Best 73, VY2RWMCannot find any specs no matter what I google. Even called Uniden. Specs are not published. Only answer specific questions via request to head office. I find it incomprehensible that a manufacturer wouldn't publish specs. I am trying to work out a link budget which requires receiver
sensitivity. SDS200 is not a toy and can be used for serious communication work with basic info.
SDS scanner do not have a fixed sensitivity like other scanners do. It uses an automatic gain control that adapt to a several MHz wide spectrum. The manufacturer of the receiver chip calls it smart power detector. If there's only one frequency in the spectrum it will hold a 0,35uV sensitivity in all frequency bands but if other signals exists it can be 4uV as Upman once declared when asked for the sensitivity of the SDS100.I am trying to work out a link budget which requires receiver sensitivity. SDS200 is not a toy and can be used for serious communication work with basic info.
