Spectra Out Of Bounds Question...
Forts
Ontario, Canada
I have a Spectra with the 136-162 bandsplit that I would really like to force a 170mhz channel into (for RX only). If I were able to get ahold of the Lab software would this be achievable?
b7spectra
EMS Dispatcher
Cobb County, GA
On a lot of the older radios (DOS MRSS), if you hold down the SHIFT key while typing in your frequency, it could work. Example - 170.575 would be !&)>%&% . Make sense? Doesn't always work, but in some instances it has.
Forts
Ontario, Canada
Thanks! I will give that a try....
Update - Didn't work :(
Using 6.00.05 it just kept telling me that frequency was out of range.
n5ims
You may want to check out this article (Hex-Editing the Spectra RSS for 902-928 MHz Amateur Use) which specifically deals with hexediting the RSS to allow the use of the 900 MHz ham frequencies, but states "While this article is oriented only towards 900 MHz amateur frequencies, the same technique will work on other frequency ranges." You may be able to expand the range(s) using a modification of what was described to do what you desire.
Not that you'd do anything else regardless, since this technique changes the RSS .exe, always make a backup copy prior to doing any changes and only make changes to an isolated copy of the original .exe!!!
Forts
Ontario, Canada
it probably wont work .. The VCO will go a few mhz ..8 is pushing it
You are correct. Using the Lab RSS I was able to bitbang the bandsplit and load in the frequency I wanted. However when the radio rebooted I would immediately get Fail 001 when I turned to that channel. Oh well.... it was worth a shot. Guess I will just have to find another radio with the proper bandsplit in it.
Thanks for the suggestions everyone!
Forts
Ontario, Canada
I was kind of thinking that too. I will take it over to the Classifieds section and see if anyone is interested.
