Spectras, Astro Spectras, draw roughly 23 amps for 110w units. Lowband X9000s are capable of drawing even more. A 30-35 amp power supply would provide sufficient overhead, however, the suggestion of floating a battery or 2 (preferred AGM non-venting types) is the best solution.
You can find plenty of things in the shack to run directly off of 12 volts, and adding a solar panel or 2 would give you a very nice emergency station also.
