Spectra Question
fireboy
texas
I have a spectra that I bought off ebay and it does type I from what I can tell from the cards left in the pockets under the cover.. Anyway, what is involved in making the radio do type II smartnet analog... Can I just program a type II smartnet codeplug in it? the MLM is 6.15 will it work or not? any help would be appreciated!!!!
Josh
Auburn Hills, Michigan
It should do Type II... What's your radio's model number?
-Josh
fireboy
texas
its says D45KGA5JB5AK... I know it means privacy plus but it seems weird for a MLM to be that large for type I. it only had two systems in it with about 4 TG per system I dont know, I dont want to corrupt the codeplug by just bit bangin it or forget some minor detail...
Josh
It will do type II trunking, you just have to locate the single screen where you can change the system type, and I know there are like 6 screens where you can view the system information..
-Josh
fireboy
texas
I know about the trunking systems screen but Im confused... if a radio is set up for privacy plus it wont accept the the control channel frequencies in the 866.0000 range will it. I thought that you had to do something within the MLM to make it accept the freqs. to work on a smartnet system. its like the difference between an mtx and an mts portable isnt it?
Josh
The frequency range settings for the radios are basic. There's 2 splits for VHF, but when it comes down to 800 and 900Mhz freqeuencies, the only bandsplits are 800Mhz and 900Mhz range... that's it.
It will accept the control channel.
-Josh
