Spider Antenna & Coverage
orbital
North Carolina
I was thinking about getting a Spider SP800 outdoor antenna and was wondering if anyone has good or bad things to say about this antenna. I am running a Uniden BC246T and would like to take the factory rubber duck antenna off and use this. Would I get better reception with this idea..... Thanks
Spider SP800
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Possibly, up to a point - given that you use good quality coax and the right connectors.
A very real possibility is that it might overload the 246 - you see, handhelds aren't really designed to handle the large amounts of signal an outdoor antenna like this might provide, particularly if you live in an urban area. 2 common problems may occur - you may start hearing pagers, TV signals and other junk, or actually hear somewhat less than what you are hearing now.
73s Mike
LarrySC
Greenville, SC
Appears to have an SO-239 connector for a PL-259 plug. If so, not rated above UHF. Would require a PL to "F" adp so you could run RG-6 coax. This would be rated to 900 mHz. 5 elements rec and 5 ground or 10 elements rec?????? I cant tell. I built one simular for aircraft and mil-air. Mine works OK for that. All antennas/scanners/coax/connectors is a test. Sometimes it works, sometime it dont. Good Luck anyway.
prcguy
If you say a PL-259 is not rated above UHF (not necessarily true), then why would a PL-259 to F adaptor be any better?
prcguy
amen
Door Co. Wisconsin, USA.
Have one hooked up as a inside ant. works real well for me . I use it when theres storms out and don't want to hook up to the out side ant. in fear of getting zapped.
OpSec
All your WACN are belong to us
Monitoring the database
prcguy
I wondered the same...the whole setup is only as good as the weakest element, in this case the PL259 connector. Using an F adaptor doesn't make the shortcomings of the UHF connector go away.
