I am looking to split a connection and I need some help on how to do this. I have a scanner antenna with a cable coming into my house with an RG6 cable going into one of my receivers. The receiver's input is an N input so the cable male output has an N connector at the end of it. I'm looking to take this N male connector and split this signal with a splitter which covers 5MHZ to 2GHZ so that I can run two cables into two different receivers, one with an N input and the other with a BNC input. Since this type of splitter accepts an F input only, I would like to adapt the N male into the F female of the splitter and then connect two cables running from the output of the splitter with an F male on one end to a BNC male connector on the other end to a receiver number 1 and then connect a cable with an F male to an N male connector to the other receiver number 2. Can this type of connection be done this way or do I need a power divider to do this? Please offer your suggestions and opinions regarding this kind of connection and where I can obtain the required adapters, splitters and power dividers, if necessary. Thanks.
