Sportcat 200. hard reset?
Hard Re-Set On Sportscat SC-200
HI-Hope this help you sir.
Happy New Year to you.
Bob
To RESET:
- Power the scanner OFF
- Power the scanner back ON
- Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner
- Gently press and then release the RESET button inside the hole.
NOTE: RESET will NOT erase the data that you've programmed into the scanner.
If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
- Press 0 then 1 while "Welcome to Dual Trunking" is displayed.
- "Initializing Please Wait" will appear for about 2 seconds.
DO NOT power the scanner OFF until the INITIALIZE process is complete (M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure will reset the scanner to original factory settings and erase all data that you have programmed.
kirk23
Pierrefonds (West Island Montreal) Qc Canada
Thanks Bob...
I thought it was the reset button too with the paper clip..but appearently that hole is not ob the Sportcat200 ..,so i assuming its the 2nd method you've offered..
I have passed the info along..
i am trying to help a french speaking guy here in Quebec and its been years since i even held a sportcat200..
i appreciate you help and time ..on his behalf i thank you.
