For what it's worth, I can receive Spring Valley just fine on a bcd325p2 from southern westchester county in NY, just across the river from southern rockland/ NJ border. All the signals therefore are hitting me from one direction I assume...
glenn, I'm curious. Assuming the issue actually is multipath, are you using the telescoping antenna that came stock with the scanner? If so, do you have it extended all the way out? And, if so, have you tried collapsing it?
I came across a device that sounds promising: Uniden HomePatrol-2 Scanner which has TDMA Phase 2 capability.
I'm not clear if this device operates on the proper band (since the Rockland system is 700 MHz).
Would this device do the trick?
Thanks again.
