Springs CSP
Steve2003
Colorado
Check the CO DTRS database. There is a map of the CSP districts. Next, look at the talkgroup list and see which talkgroup that particular district is on. It is important to note that sometimes there can be more than one district on a talkgroup. I often hear ^A and 6B on the 6A channel. Let me know if you have any more questions.
INDY72
Indianapolis, IN
Look up at the top of this page.. ^ :)
AngelFire91
Scroll to the top of this page then make the following clicks;
RR Database
Colorado
State of Colorado APCO-25
All the information is right there, Springs is 2B there is a listing for 2B Disp and 2B Tac.
Thanks,
Kevin
(Colorado Admin)
mpdonala
Colorado Springs
By the way could you tell me what system frequency sites to use if I live in Colorado Springs to get the best listening. I work in north C/S and live in south C/S. Thanks Mark
jimmnn
Colorado
By the way could you tell me what system frequency sites to use if I live in Colorado Springs to get the best listening. I work in north C/S and live in south C/S. Thanks Mark[/quote]
I would start with Cheyenne Mtn to begin with but remember only CSP is on DTRS down your way all El Paso and Colo Springs comms are on there 3600 baud Moneyrola trunked system which you will need to program seperatly.
Jim<
mpdonala
Colorado Springs
Thanks Jim. Also new to programing the bearcat radio. I have the software to program with, can you tell me can i put all of the control freq's of the local sites or do i have to break each site down into seperate locations to get my tag groups to work?Any help would bee appreciated. Thanks Mark
jimmnn
Colorado
Are we referring to Colorado Springs programming or DTRS programming?
First off for DTRS in your area you only have 2 or 3 control channels at the most and while it's not necessary, I would recommend those in different banks if you can.
Are you using the Pro-96 (excellent radio btw, I have three), if so I would highly recommend win96 for all your programming needs.
Jim<
mpdonala
Colorado Springs
Thanks Jim. I could not tell you how I need to program I have a bearcat 250D. Trying to get any info from the radio people around here is like trying to get a date with the Swedish Bikini Team. LOL Everthing I have learned so far has been self taught. Kinda hard to learn that way. I had it programed but I had to put in all the freq. I had for the entire springs area. Finally was told abpout this web site by Uniden Tech support and am leaarning quickly, but sure there is alot more to learn. Thanks again Mark
jimmnn
Colorado
Still confused if you are trying to program the El Paso County and Colorado Springs 3600 baud system or the States DTRS system? They are different and require different instructions.
We also have a few dispatchers in the Springs who are very familiar with the trunked systems programming and I'm sure would be able to help you directly. Bob's Colorado Springs feeds are also available on-line if you want to monitor them.
I would avoid the so called radio stores, they are a last resort and frequently ill informed in my experience.
When I first got a Pro-96 mail order in September 2003 I took it down to a local Radio Shack store and inquired if they knew anything about when the Pro-96 would be available and he said not for a few months and that it was "useless anyways because none of the Colorado digital system was monitorable" so I took my programmed Pro-96 out of the bag and it started talking, I think he almost fainted and would not let me leave the store he was calling others to come see etc etc.
Good luck.
Jim<
AngelFire91
Ok, Here is a couple of problems.
1. I think you are wanting people to tell you exactly what buttons to press and when. We can't really help you there everybody uses different scanners and radio's and they all have different sequencies, and plus wouldn't you rather learn how to do it so you could do it again when you want to change systems and such, or would you like people to just tell you. I've always been a fan of learning with direction. We will direct, as long as you are willing to learn.
2. We need to know what you are interested in listening to. State DTRS (CSP, etc...) is on a 9600baud APCO25 system and is totally seperate from the Colorado Springs, ElPaso County 3600baud system (CSPD, CSFD,etc...). I have extensive knowledge of the Colorado Springs system but not a whole lot on the state system, but there are people here that have extensive knowledge on the State system, so knowing who needs to step in is kind of priority.
3. If I offended you by writing this, I'm sorry we need more info as to what you want to listen to and how you want us to help you. There are many people willing to help in Colorado not everyone of us is like the ScanColo guys.
Thanks,
Kevin
(Colorado Database Admin)
P.S. I've always lived by the saying, and feel free to use it, it came out of a fourtune cookie;
"Do not give a man a fish, but rather teach him how to fish."
mpdonala
Colorado Springs
Thanks Jim and Kevin I am not offended and rest assure I want to learn this pretty bad I don't want anyone doing things for me. I just need to know the direction to go because there is very little info for programing. I am most interested in the C/S El Paso system with the hope that I can get CSP also. I know there is a way to use control channels at the different sites or if I just need one main control channel. Like I said befor work north live south. Being a member of the FD I know the system does not work the greatest even with the $3500.00 radios. Any help in which direction to go would be helpful. Thanks again guys Mark
Steve2003
Colorado
If you are using the BC250d, you must have the digital card to monitor both the colorado springs and state system. Secondly, if you have the 250d, you will not be able to track talkgroups on the state system because it uses a 9600 baud control channel. You will need the uniden bc 296, uniden bc796, or the Radio Shack Pro-96 to track talkgroups on the state system. Your BC-250d should monitor the Colorado Springs system just fine. You can still monitor the state system as long as you program in all of the frequencies for the system as conventional. You will be able to hear the audio, but will find it difficult to follow talkgroups because the frequency is always changing.
Le me know if you have any questions and good luck,
Steve
AngelFire91
Hey,
Shoot me a PM and I'll help you out more, Please provide what scanner you are using, I might not be able to tell you exact keys to push but I will help you with the sites and talkgroups and systems all together.
Do you work for Springs FD? If so What station? I am also a FF in the Springs,
Thanks,
Kevin
whitehme
Any Win96 files for Colorado Springs/El Paso?
I just purchased a Pro-96 scanner and was looking for any pre-programmed Win96 frequency files for Colorado State, Colorado Springs, El Paso, Denver, and the general front range.
Thanks!
jimmnn
Colorado
Re: Any Win96 files for Colorado Springs/El Paso?
Thanks!
Have lots of win96 files for Colorado but most of the Id's focus on the Denver Metro area and the Mtns.
E-mail me directly to receive a copy; jimmnn@comcast.net
Jim< :lol:
