Squelch control
SA_tx_88116
Rather listen than to stream
Cibolo, Texas
I have the Uniden bcs325p2 set on highest 15 and still get static and noise. Any suggestions?
These frequencies are called birdies they are created in the scanner they are just noisy channels or interference. but to help you more I need to know what your listening too
tvengr
Well Known Member
Baltimore County, MD
Remove the antenna and see if the noise goes away. If it does, you have something interfering with the scanner. Unplug any electronic devices in the area. USB switching power supplies are notorious for causing wideband interference. Squelch should normally be set at 2 on the BCD325P2.
Whiskey3JMC
DXpeditioner, RRDB & Google-fu ninja 4 hire
Philly burbs 🇺🇸
Move away from sources of RFI to eliminate that as a possibility (same thing happen outdoors?). Were you ever able to monitor your local agencies after performing the DMR upgrade or is this something you just tried? If said "static" sounds like this (turn volume down) then either you did something wrong with the upgrade or there are errors with your programming.
Press Menu. Scroll to Settings (press E) then Upgrade (E). Scroll to Upgrade DMR/MotoTRBO (E) and the screen should read "DMR/MotoTRBO has already been activated" if the upgrade was installed successfully
Monk68
Cookeville Tn
The DMR was purchased as an upgrade with the scanner. I had the scanner programmed remotely by the company. This was a Christmas present so I know nothing about programming these scanners. Do you think the programmer did not use the upgrade?
jtwalker
Gettysburg, PA & Fenwick Island, DE
And this is why most on here will recommend against having the retailer program a scanner for you because there is no avoiding the owner from needing to know how to program it. I realize this may have been a surprise gift and you didn’t have input on the process, but you might as well accept the fact you will need to learn to program it.
tvengr
Well Known Member
Press Menu. Scroll to Settings (press E) then Upgrade (E). Scroll to Upgrade DMR/MotoTRBO (E) and the screen should read "DMR/MotoTRBO has already been activated" if the upgrade was installed successfully.
The conventional frequencies in Putnam County are why I asked the question about selecting talkgroups by slot only. That is PC-911 Ops 1 & 2 in the database.
Monk68
Cookeville Tn
Does this mean my upgrade has been installed?
