SDS100/SDS200: Squelch issues: SDS-100 NXDN
Whiskey3JMC
Another Pesky Scanist
Simulcastylvania, TE
You're going to need to be more specific about what a "squelch break" is. What are the specific symptoms? Is said NXDN a part of a trunked system & if so, do you have it programmed as such with correct RAN code(s), LCNs, etc? Is it listed in the RR database? Are you using Sentinel to program? Too many variables come into play to provide a definite answer. If you're hearing data bursts in between transmissions then something is wrong with your programming
Ubbe
Stockholm, Sweden
How do I set my SDS-100 on a NXDN system to prevent annoying squelch breaks?
Program the audio mode to Digital Only. Then it would be impossible to get any squelch breaks. Of course any kind of priority setting would briefly switch over to another frequency at something like a 2 sec intervals. If you set the display to detailed mode it would show any priority function being enabled, like a WX symbol or similar indicator.
/Ubbe
safetypro79
Scanning since 1967
Anchorage-Alaska, Boise-Idaho, Salem-Oregon
Thanks so much, I can change the audio to digital for the system in my favorites?
I don’t want to effect any conventional UHF/VHF frequencies in other favorites list
John
Live long and prosper 🖖🏻
safetypro79
Scanning since 1967
I did get the digital mode enabled. Was in :All
That’s why the intermittent repeater buzz
Thanks for your assistance I’m most grateful I’m still learning the 100
dave3825
Suffolk County NY
Are those freqs good and valid and still belong to the entity in question? License says it expired 8 years ago.
