Squelch. Noise9
rogerd1944
On the 996p2 is it common to not here static when setting .I have mine set at 2 but I don't here any noise and then back off like I am use to
baker50021
Ankeny, Iowa
It depends on what you are scanning, conventional channels should here static when squelch is at 0. Trunked systems usually won't hear static because the scanner is monitoring the active control channel.
tvengr
Well Known Member
Baltimore County, MD
The normal squelch setting on the 996P2 is 2. For a digital trunked system, you will not hear noise. For conventional analog frequencies, you will hear noise only if using carrier squelch (no CTCSS or DCS tone programmed). If tone is programmed, you will not hear noise.
