Squelch/Repeater Tail
AE106
Tennessee
I'm new to using selective calling. We just recently began using it (fleetsync) at the EMS service that I work for. Add I understand it, Kenwood selcall is private transmissions between the two radios participating. Is this a radio to radio transmission or is this still using the repeater/channel that the radio is on? If it is private, why then do we still hear the repeater/radio close when someone in a selcall releases the PTT?
cmdrwill
So Cali
All depends on how the system is set up.
Fleetsync and selcall are two different things.
AE106
Tennessee
So attempting a selcall had nothing to do with the fleetsync or day MDC? I thought that one couldn't do a selcall unless both radios wetter running the same- P25, fleetsync, MDC, etc..
ramal121
Lots and lots of watts
Calif Whine Country
Private call will not change the channel characteristics be it a repeater or simplex. Fleetsync can be used as a more advanced signalling system than say PL/DPL.
For selcall with fleetsync, all radios are muted to radio traffic. You don't hear anything. Someone can send the selcall ID to a certain radio (or group of radios) which will unmute the speaker and allow conversation. There is a timer that keeps the radio open for back and forth traffic. When the conversation stops the timer expires and puts the receiver back on mute.
This only works when "And" squelch is used and all means on monitoring the channel are disabled. Otherwise the conversation wouldn't be private would it?
