Squelch setting
TDR-94
Does the squelch setting have any implication/bearing on P25 conventional channels if the signal is digital?
ElroyJetson
Not really. Basically squelch on a digital channel follows an AND rule. Signal must be present AND it must match all required data constraints (system, group, and unit ID) before the radio must unmute, so I don't think that it makes much difference except that if squelch is set too tight, it can reduce effective sensitivity and receiver range.
Adjust squelch for proper operation on that frequency in analog, and when you switch to digital it'll be fine.
TDR-94
I've noticed that the receiver will sometimes stay unsquelched if the squelch setting is too low on certain analog channels,but I wasn't sure if raising the squelch adjustment level much higher, to eliminate the issue, would affect the sensitivity on digital receive.
