Squelch Settings
glock17
Lake View
I've noticed that when I put the radio into scan mode the scanning will stop on channels at random, I keep turning up the squelch for the radio and have SQL tight checked for the channels. It seems like I have to make the squelch much higher if I make it a scanning radio instead of just monitoring one channel. Does anyone else have to do this as well?
The model is F121S
The squelch is set at 240 and the sql tight offset is 255 and the radio still gets hung up on channels where there is no traffic.
icom1020
hmm I checked my CS-F100 file in Set Mode and mine is set at 75
I have noticed with another Icom, it would lock up on a channel in scan mode until I touched the monitor button briefly, and then it would resume scanning.
icom1020
SET MODE
Tone Burst NO
Reverse Burst Timer 0.300
RX AF Filter NORMAL
EXPERT MODE
User CTCSS freq 88.5 not sure why, it that the default?
gewecke
Banned
Illinois
Some of my radios have "hysteresis" type squelch and they tend to have the same behavior.
I think this is common with radios that use H squelch.
N9ZAS
glock17
Lake View
N9ZAS
ah ha, that makes sense.
I'll have to do some testing to see what the impact of my higher squelch setting is.
Hopefully the h squelch will adjust
Metrofire31
Auburn-Opelika, AL
Squalech on Icom F3021 VHF
In similar fashion to what has been described here. I've noticed than when I program freqs with CSQ squelch, the radio in scan mode will invariably stop on only the CSQ freqs. What settings should I adjust to stop this?
glock17
Lake View
I have not found a solution to this yet either.
I think I'm going to have to start using tones on my channels.
