squelch wont turn off
mitbr
Tampa Bay Florida
squelch wont turn off 536hp
Is there a way to turn the squelch off to listen to the data channel on a trunked system on the bcd536hp?
LiquidPandora
Ya I have noticed that too... you turn it to zero and it will sit there and think about it... I have also noticed the sound does strange things the same way... if you don't break the squelch and screw with the volume I have found myself sitting for hours in silence just to go OH ****! and fix it and then you hear it... Garbage tech
mitbr
Tampa Bay Florida
I listen to the data channel on the 996xt and home patrol 1 to determine when tropo skip comes in to listen to distant trunking systems and to select the strongest site on simulcast systems.
I tried this on the 536hp and the squelch wont open.
I wonder if this could be fixed in firmware?
Tim
JoeyC
Senior Member
San Diego, CA
Of course you can listen to a control channel on the x36 scanners. Program it as a conventional item and listen away. If that's what floats your boat. I doubt there will be any firmware change to make a control channel audible when listening to a trunked system. That would not make any sense.
mitbr
Tampa Bay Florida
Hi Joey.
I never thought of that thanks for the suggestion although it is still a work around.
I don't want to hear the data channel when scanning a trunked system either lol.
I just want to be able to hear it by selectively opening the squelch.
phask
KZZV - SE Ohio
I use a HP1 - and on it it's about 3 key presses to hear the control channel.
I'd think there is something similar.
Pause on trunked system - advanced - site info - choose site - site freq. -select
This may be added when analyze comes out , but I'd be surprised there is something an HP1 does that these can't.
mitbr
Tampa Bay Florida
I also have the hp1 and it is nice to be able to hear the data channel on it.
I guess we can hope that the analyze feature will add this in the 536hp they are both similar in design.
