SRP -- Salt River Project Agricultural Improvement & Power District System
ctrl
Phoenix Area.
I have logged a few talkgroups for this system, Hoping to get some help identifying them.
http://www.radioreference.com/modules.php?name=RR&sid=4900
Site-001--Phoenix:
289
294
296
297
298
300
304
305
325
336
338
340
342
i12106
i12350
i13633
i13693
i14452
i14509
i14548
i14611
i15081
I'm new to monitering edacs systems, and I have I-call on. I thought I-call ID's were all in the 7xxxxx range. So im not sure what the "i" stands for in the last set of TGID's.
FLANO
AZ DB Administrator
SE of Tucson, AZ
Hi thanks for posting those.
I discovered this system while up in Phoenix. At the time I didn't get anything off of the system, other than the control channel at the time for site 1 was 939.90mhz. I use the Unitrunker software for helping to ID systems. It labeled this frequency as LCN05.
Are you hearing the control on a different frequency?
Are you just using a scanner or are you using software to help ID.
Thanks,
John
SE of Tucson
FLANO
AZ DB Administrator
SE of Tucson, AZ
The skip this morning helped a little. I am showing 939.40mhz currently active as the control frequency. It is showing it is from Site 1, LCN02.
According to the frequency plan with the FCC this should be the site from Glendale. I think with EDACS, they don't label the sites so cleanly for us like Motorola does :<
I picked up a couple of TG's:
338
342
John
SE of Tucson
EricCottrell
Boston, Ma
Site-001--Phoenix:
i12106
i12350
i13633
i13693
i14452
i14509
i14548
i14611
i15081
Hello,
I think the 7xxxxx is used as a way to enter an I-call ID (You enter a 7 because there is no i on the keypad). The i prefixed groups look like radio ids displayed during I-call. I have a BC396T and it displays the lower case i followed by a number during I-calls on a motorola system. It could be that older models displayed a 7 instead of an i on the display.
73 Eric
ctrl
Phoenix Area.
Hi,
Im currently hearing the control channel on: LCN 02 -- 938.9625 for the 'phx site'.
At the time of me posting these, it was on 939.4. Appears they switch the control channel often?
I am not using any software at this time, just the bct396 logging the ID's.
I cannot get the glendale site to receive at all, and im in peoria.
As far as the I-call's when I recieve them here on the Maricopa County system. They are always prefixed with a 7xxxxx (720268, ect.). I'm using 700000 as the wildcard.
So how would I go about entering these into the scanner?
Would I use the 'i' or would it be prefixed with the '7'?
FLANO
AZ DB Administrator
SE of Tucson, AZ
Looks like you are on line, try 939.4125mhz. I am hearing the signal from Glendale via the skip down here south of Tucson.
John
SE of Tucson
FLANO
AZ DB Administrator
SE of Tucson, AZ
ctrl said:
Hi,
Ok, I can apparently hear Glendale via skip today. 939.4125mhz is LCN03.
As far as switching control channels, that's not uncommon for switching every day.
John
SE of Tucson
ctrl
Phoenix Area.
John
SE of Tucson
Ahh you are right, this is the current active, my scanner wont lock onto it while scanning, but if I hold on this channel, I hear the control channel data.
Just not enough signal my way I guess, strange.
FLANO
AZ DB Administrator
SE of Tucson, AZ
Here a few more TG's that I have logged for this system. These are courtesy of the Unitrunker software:
302
324
329
805
1574
2004
