325xia
325xia, The solution is described many times previously in this thread....The information is there if you look and are willing to take the time to understand your scanner.
To help I pasted in information from Scanner master below to help understand the reason you need to change to a custom band plan and how to program band plan 1 and 2...
Motorola trunked systems assigns users to specific Frequencies, although by use of conversion “Tables”. For this reason, Control Channel Trunking works well most of the time on Motorola systems, the scanner understands the instructions from the trunked system’s control channel to look up the assignment code in the Table programmed into the scanner and then send the scanner to the proper frequency to look for that conversation. Tables contain the formulas used to determine the frequency from the computer code on the control channel. Standard 800 MHz. systems have used the same table for years and scanners were built around these Tables. Rebanding changes the Table so scanners will need to be updated for these changes. Since some older scanners do not have the ability to be updated those older scanners will no longer work on rebanded Motorola systems.
During the conversion process however there are multiple Tables in use, the original Motorola Tables used on non-rebanded systems and the new Tables used by rebanded systems. Further complicating the matter is that the final version of the Table may not be etched in stone until the Rebanding project is completed some years down the road.
For these reasons scanners of Rebanded Motorola trunked systems in the 800 Band will need to use the Custom Tables feature of the BCD396XT to monitor rebanded systems.
Programming a Rebanded System When setting up the scanner for a Rebanded System in the 800 MHz. band you set the radio up for Motorola trunking then select “Custom” in the Band Plan section of the Menu. You then set the Base Frequencies and other parameters as shown below:
Band Base Freq Base Freq Offset Polarity Spacing
Plan Lower Upper
1 851.0250 854.0000 440 + 25 kHz
2 851.0125 868.9875 0 + 25 kHz
Then go back and enter the frequencies used on the system.
