Does anyone have a Win96 file they can send me and I can just insert into my Win96 program to set up my Pro-96. All this talk is making my head spin.
Ron
Ron
If you have the BCT15X, not the BCT15, then 1.03 is the current firmware. The BCT15X supports rebanding out of the box, so all you need to do after entering the control channel frequencies is set the bandplan, which is the same for all Uniden scanners (GRE/RadioShack scanners use six different bandplans instead of the two that Unidens use).hi Everyone, I bought a bct15x because my bc780xlt would not support the rebanding. Today I tried all the different suggestions in this thread and still couldnt get anything to work. I just noticed something though, my firmware ver is 1.03, I think the rebanding is only on ver 1.06 and newer. Does anyone else have a bct15x that could please let me know? I dont have the pc cable so looks like I may have to purchase one. If it turns out that I do need the firmware update would anyone be able to help me with this at the meetup? thanks
That was very helpful "benca". I was going through 14 pages on this thread to try and figure this out. Thanks for doing that work for me. I just didn't understand that it needed the "Custom" banding. thought I could enter the Red Control Channels of the rebanded system and be set to go. As, people were describing here that the 396xt does all the work for you. Obviously, that is not the case in this system. Thanks again for the explanation and the correct Band Plan.
I realize what a pain in the neck this rebanding process is. It is even more of a pain to find someone to reprogram your scanner. Perhaps I can help. Give me a call. 916-508-0672. My name is Stretch.
Can you post the custom plan? My OFD has stopped receiving?
just bought my uniden bcd396xt....very overwhelmed......way over my head....please cal 916 802-3773 mike
Turns out that on my 396xt that control channels were not enough. I had to add a custom band plan for both sites in order for it to work. I used the one listed in this thread, and from Scannermaster.com
As soon as the new band plan was in place, everything starting tracking.
1 851.0250 854.0000 440 + 25 kHz
2 851.0125 868.9875 0 + 25 kHz
My firmware is 1.07.00, and I can't update to the newer one, (check my COM settings, yeah, right, Freescan works fine). Oh well, seems to be working now.
Thanks.
Are you sure you are even receiving the frequencies you are missing? I'm closer than you and I have trouble. When you are at a far enough distance like we are the signal is seriously going to ebb and flow.Are there any other custom bandplans I can try? This one doesn't seem to be doing to trip 100%. I'm hearing transit traffic on A3 which I'm assuming shouldn't be there.
The bandplan you quoted has an error. It should be:Are there any other custom bandplans I can try? This one doesn't seem to be doing to trip 100%. I'm hearing transit traffic on A3 which I'm assuming shouldn't be there.
1 851.0250 859.0000 440 + 25 kHz
