Ben96cal
Is it just me or is it really quiet? I haven't picked up a thing in 25 minutes.....ugh..
------------------------------------------------------------If someone is creating the bandplan by hand, rather than using one that might be pre-programmed; I'd use the following:
BASE: 851.0125
LO: 0
HI: 439
SPACING: 25.00
BASE: 851.0250
LO 440
HI: 559
SPACING: 25.00
I have a rock solid 10 on a scale of 1-10 receiving 853.8750 (@ 07:50) with 99% decode (highest it goes). It sounds like you are programmed off a bit.
You should start a new thread on your issue. And in that thread tell us what model scanner you are using. Many older scanners will NOT be able to trunk track this new system. You can scan the frequencies, but the scanner won't automatically calculate the proper voice channel. Newer scanners will work, but you have to program in the correct band plan.[/QUOTE
thank you....do you of any stores or persons that will give or...help for hire like the old stores off of power Inn rd ? and I will try a New Thread....TU
Is there a bandplan for the city system and if so what is it?
Lower 851.025 upper 854.0 step 25.0 offset 440
lower 851.025 upper 868.9875 step 25.0 0
Didn't hear anything on the "standard" bandplan. Hearing some now on the one avtar sent out, however still not hearing most.....Missing alot of dispatches
