ST-2 VS. Homebrew
N4DXX
In the pines where the sun never shines
I have been scanning for 30 years and mostley used a st-2 for the last 20 years..I seen one homebrew on ebay for 37.00 in a pvc tube and thought i would like to see how good it really is..Well i must say it's amazing for wire in a tube..Better than the st-2 on the aircraft band and seems to be better on uhf..I don't have any systems on 800mmhz so i cant comment on that but if it's anything like the other's it will be great..I can say if your on a tight budget this thing rock's and does what he claims,Some will say snake oil but i don't care it's side by side with the st-2 on a 50ft tower and it does as good as i just said..And on VHF/UHF it's somewhat better..I know the st-2 is no longer avalible..This would be my choice.If your on a budget as i am.
iMONITOR
Silent Key
S.E. Michigan
I have not looked inside the pvc but for 37.00 it would be hard to beat..It's neck and neck with the st-2 on uhf/vhf..I would say slightly better
Any wire outside will perform will work OK. Why not make your own for $0.00 if you have materials laying around the garage/basement. Or buy what you need for a few bucks? That would also give you the opportunity to tweak it for a particular band if desired.
N9JIG
Sheriff
Moderator
Far NW Valley
It looks like the same idea of the Austin Ferrett, several vertical dipoles with a common feedline. If done right it should perform much better than a discone.
217
Sporadic E enthusiast
North Carolina
There is a photo of whats inside somewhere on this site, from 2017 maybe.
Ubbe
Stockholm, Sweden
It could be that the ST2 are too efficient and gives too high signal levels to your scanners/receivers/active splitters so that they overload and de-sense. Using a less effective antenna will cure that. A variable 0-20dB attenuator are always a good tool to have when dealing with external antennas.
/Ubbe
