St. Charles Co. MO.
KM5LZ
O'Fallon, MO
I am looking for St. Charles County Highway Dept. frequencies used by the snow plow trucks..
N0IU
Wentzville, Missouri
I don't know where you are, but out here in the "Boonies" (Wentzville), MODOT plows I-70, I-64 and I61. We are in District 6 (St Louis District) and the only thing I could find in the RR Database is the MODOT District 6 - Mobile-to-Mobile frequency of 151.070 MHz.
As far as St Charles County, the RR Database only shows 2 frequencies for the Highway Department, 158.745 and 159.105 MHz.
As a (somewhat) interesting side note, I managed to get in front of one of the gang plowing teams one night and saw that the trucks use green lasers beams pointed down the road apparently to keep the proper spacing between the units. I guess this gang plowing thing is more of an exact science than I thought! As efficient as this method is for clearing the road, it is a real PITA when you are behind them... and late for work!
KM5LZ
O'Fallon, MO
St. Charles Co. MO
Hi Scott
Thanks for the reply I have the two frequencies that are in the data base and have heard what sounds like a dispatcher maybe twice. You would think that they would have comms. between each trunk. The only thing I can think off is if they are simplex which really does not make any sense. I think the county has a road dept. in your area also.
ElGenio
M
Thanks Scott for the frequencies as well. I've never considered us to be out in the "boonies." though.
Since this thread is on St. Charles Co there was some nice listening last night. They had Air-One, O'Fallon and the County searching for somebody off of Hoff Rd & P. Air-One was on the county's dispatch channel and O'Fallon was using their 809.### too. I thought they stopped using their old system.
KM5LZ
O'Fallon, MO
O p d
Heard today at 11:15 AM O’Fallon PD on 854.6625 they are definitely using there old frequencies for private comms.
N2JDS
St. Peters, Mo
Due to several requests on a survey I did, many people wanted just EMS and Fire on one feed, so I've added a feed of just the 16 channels we use
1 Page Out Channel 154.250
2 Operations 155.940 Most Ops. done on this channel
3 OPS. Channel 3 154.085
4 OPS. Channel 4 158.835 Second most comman Ops channel
5 OPS. Channel 5 158.865
6 OPS. Channel 6 154.445
7 Admin./Ch. 7 154.515
8 Fire Mutual Aid 154.280
9 EMA 155.835 locked out, too much deputy chit chat
10 HEAR 340 155.340 locked out, too many helicopter patient reports
11 Lincoln Co. EMS locked out
12 Warren Co. EMS locked out
13 Fire Ground Ch. D 154.295
14 Fire Ground Ch. C 154.265
15 Fire Ground Ch. B 155.325
16 Fire Ground Ch. A 153.830 This is the one most fireground calls are on
It will be quiet when no calls are going on, so be patient.
St. Charles County Fire and EMS Live Scanner Audio Feed
N2JDS
St. Peters, Mo
New EMS and Fire only feed
stlouisx50
Mountain Grove, MO (Texas County)
Sorry to reply so late. MODOT District 6's St. Charles County Frequency is 151.040. 151.070 is west of St. Charles County.
