St. Johns County P25 (4D6.BEE00)
bravo14
Polk County FL
The past few visits I'm seeing new TG's. I think they are setting up Interop tgs for surrounding counties for mutual aid. There is alot of ENC tg's showing up also.
wsmoore
Jacksonville,Fl.
No they are the ISSI TG for interop Flagler Fire can show up anywhere between 20000 to 20200 tg range in the clear and the Sheriff's Office can show up in the 20000 to 20200 tg range ENC. Not sure if Palm Coast has PD and FD still,but if so they will use them to if close.They are used for interop, but also because at the North end of the County the signal gets weak and if it does it will use the tg on St.Johns County system at the southern end of the county for stronger coverage. Because the St Johns System is Simulcast you will hear them on every site in St.Johns County.
flaw101
Fruit Cove, FL
Thanks for the clarification. On another note, does anyone have a list of RID Aliases for SJ Fire Rescue? I'm trying to identify them manually.
bravo14
Polk County FL
Seems Flagler county tgs popping up on the sjc 800 system. I hear fire than fire/police. There’s some new tgs in 20xxx
