St.Mary Parish Sheriff
Davidarambo
Crossville,Tennessee
Im kinda new to this hobby and usually have my Uniden BCD 436HP do everything auto. My zip code is 70523. The local small town is like analog I believe and then the sheriff is digital and maybe trucked, which I’ve never heard. What would be the best set up to listen to everything? I live in St.Mary Parish in Louisiana. And would like to hear the sheriff Dept. in the auto mode I basically hear everything I want except the St Mary Parish Sheriff. Thank you.
shew
PIERRE PART, LA.
U should hear everything...in st Mary parish I live in PIERRE part and I can catch the Baldwin digital tower
Sent from my iPad using Tapatalk
shew
PIERRE PART, LA.
If u used the zip code ...it should be programmed in ur scanner
shew
PIERRE PART, LA.
yes...the antenna that came with the scanner is crap....i use the radio shack 800mhz rubber ducky antenna
teebee
Lake Charles, LA
In you live in the zip code area you posted you will have no problem picking up the Jeanerette, Baldwin and possibly the Berwick LWIN sites
Davidarambo
Got it. Actually created a favorite list and been picking up St Mary SO and Berwick and Patterson PO. pretty cool. So is Iberia Parish different? I did the exact same thing on making a favorite list and had my scanner on all day, I heard St Mary but no Iberia. Had both systems turned on but only heard St Mary
shew
PIERRE PART, LA.
Iberia sheriff is encrypted..U will only hear fire and public works
