Hi- I'm having issues and wanted to know if anyone else is having similar issues or have ideas on how to fix this. I have the new Uniden Phase 2 TDMA desktop scanner and I am trying to receive St Mary's but I get nothing at all- at home and even when I am within 3 miles of the Leonardtown tower. I have it in as a X2-TDMA sytem- uniden's software puts it in as a standard P25. All talkgroups entered in correctly along with Freqs- I know this because Prince Georges has the same system and I pick them up fine. Ideas? Issues? I have all of the encrypted talkgroups locked out but I hear nothing at all.
PG started as X2-TDMA but switched to P25 Phase 2 TDMA a few months ago.
St. Mary's was never X2-TDMA - just P25.
I believe the St. Mary's system is designed to be "P25 Phase 2 compliant" meaning at some point they will go to TDMA (Phase 2). However, from what I recall, when it came on line in August, it was functioning as Phase 1 (FDMA) and you should have been able to receive it using any current/standard digital scanner.
Have you ever listened to this system before (the x36)? If so, on what model scanner?
If you are using a Uniden 436 or 536, you should be able to load the St. Mary's system in from the library and it should just work - no special settings required. The only possible "tweak" I would probably do is to remove all but the active control channel frequency from the programming (but that is really just an option to optimize reception).
Keep in mind that much of the system - sheriff, local police, state police, etc. are all encrypted. You should be able to hear fire and some other government and transportation talkgroups - assuming they haven't gone full bore on the encryption.
Funny - I've been curious to take the drive down there and see how well the 536 works - just haven't made it down there yet. My PSR500 and PSR800 worked on the system back in August but not very well unless I was stationary in a "good spot" (very similar to other P25 systems with digital simulcast issues).
