st.paul police and fire
tjoselyn
I am having trouble recieving st.paul fire and police ch 2 and 3. I am recieving st.paul police ch 1 just fine. I DO have the correct control and alternate channels and talkgroups in my scanner. i live in the forest lake area using a 10 beam yagi facing the southwest.. Is anyone else having trouble?
mutty444
TWIN CITIES MINNESOTA
I am having a similar problem with hennepin county
I pick up dakota and ramsey county just fine, before the rebanding, i heard henn county and mtco very well, I have the correct freqs programmed in. this may just be an antenna issue.
tjoselyn
my antenna is a new antenna mounted about 15 feet above the roof.... i really am baffled over this problem
wogggieee
Hugo , MN
you might do better with it pointed more south or southeast rather than southwest if you're trying to get st Paul. You have to have the antenna pointed at what you want to hear. I get st Paul fire fairly decent oin the Ramsey co system from inside me my home in Hugo with a 800mhz antenna on the radio.
