St. Paul Police/Fire ARMER frequency(s)
Angelica231
I've been away from my scanner for quite a while and just recently reactivated the two GRE Pro scanners. I actually had to take out the manual and re read it. . I am currently listening to Ramsey Co. East. I'm at a loss to find the ARMER freq's for St. Paul Police and fire. Pro'lly missed it. Any help?
Ang :)
ofd8001
Louisville, KY
See: https://www.radioreference.com/apps/db/?sid=3508
St. Paul Police and Fire mostly use the Ramsey County Simulcast site (control channel frequencies). Their talkgroup IDs can be found in the Ramsey County - St. Paul talkgroups section.
Hopefully you have programming software as hand-programming is a nightmare. With you being a premium subscriber, you can use your software to import the correct data.
I'd also suggest you program the Statewide interoperability talkgroups along with the Metro Interoperability talkgroups (ME Tacs). Lots of good stuff can be heard on them.
wogggieee
Hugo , MN
If you're on the Ramsey county system you should be able to hear them by putting it in ID Search mode or whatever the equivalent on a GRE scanner is.
Angelica231
Hi! Thanks so much for the help! I very much appreciate your thoughts. :) Ang
