kpoe_28
Does anyone know if the ST4 works as well as the D130J ?
Diamond D130J Super Discone Antenna:
Specifications:
Bands: 25-1300 MHz
Gain dBi: 2 (nominal)
Max Power Rating: 144 MHz up: 200 watts
6m: 20 watts FM, 50 watts PEP
Height: 5.6'
Weight: 2.2 Lbs.
Connector: UHF
Element Phasing: Wideband Discone
AntennaCraft ST4:
Features:
Compact Design - allows flexibility when choosing an installation site.
Low Wind Resistance and Lightweight - allows higher mast mounting.
Resonator and Tunable Whip - for best 50 MHz performance.
Easy Assembly and Cable Connection - uses rugged stainless steel hardware, radiator rods, and standard supplied SO-239 terminal and attaches to PL-259 cable connector (PL-259 connector not supplied).
Specifications:
* Scanner-Ham Discone Antenna
* Frequency 25 - 1300 MHz
* Overall Height: 44"
* Fits Mast Pipes Up To 1 1/2" Diameter
Specifications:
Bands: 25-1300 MHz
Height: 5.6'
Weight: 2.2 Lbs.
Connector: UHF
AntennaCraft ST4:
Features:
Specifications:
