BCD396XT/BCD996XT: sta75
danzan77
Findlay Ohio
Still trying to figure out the scanlist myself. I have a somewhat understanding of it but just not quite there.
Sent from my LGL52VL using Tapatalk
kb9hgi
IL
are you guys trying to manual program? It's easier if you use software to program them. there is a program called Free Scan and its free to use and program your scanner.
W8RMH
Feed Provider Since 2012
That model has had reports of the ribbon cable which connects the keypad to the circuit board coming loose. If you feel comfortable opening the case you can make sure the connections are seated.
danzan77
Findlay Ohio
I used the software but also want to be able to manually program if needed. What model were you referring to the ribbon coming loose
