Standard vs. Splinter 800 type
teebee
Lake Charles, LA
I am wondering how do I know if my system I am wanting to program in my scanner is a Motorola 800 Mhz Standard or Splinter. The software I am using gives me the option between the two. I did no know there were something else other than standard. I am interested in knowing what is the difference as well. In the past the only programing options I had was 800 type I or II.
RISC777
Splinter systems have frequencies below 866 MHz that end in 0. For example, 851.0250 would be the frequency of a splinter system. (Typically near international borders.)
I think this system will provide you an example, click here.
FLANO
AZ DB Administrator
SE of Tucson, AZ
Good example.
Also, you would get a clue to check if the system that you are monitoring, near the border, is a splinter system, when the scanner tracks talk group activity, but you don't hear anything from the radio.
This clue works, assuming that the system that you are monitoring is a non-digital trunking system with an analog scanner.
This works well for me, since I live near the Arizona/Mexico border, and not all trunking systems are splintered.
