Hi dose any know why when Modesto fire go to a Tactical channel i can no longer hear them even with there Tactical channels program in my scanner ?
The tactical or tac channels are also know a fireground channels. These are normally simplex, car to car frequencies that normally are used by just hand held radios. Many times (depending upon the jurisdiction) the power output of the HTs will be lowered. A good outside antenna might be needed to improve reception of the tactical traffic.
Modesto uses the centralized county-wide dispatch channel, going to the command channel that is on a repeater system. From the command channel they are assigned a tac channels as needed for the incident. Modesto has contributed two channels to the tac group of channels.
