StarCom21 - 2008-2009 -- REBANDING only
Starcom21
IL /MO/Global DB Adm!n
MetroEast-St Louis
FCC Applications have been filed for modifications to add frequencies to sites:
If someone would match each of the listed address below with site #'s and reply back to YahooGroups, it would be appreciated.
See infomration on YahooGroup Message page
cubn
Marion/Johnson County, IN
ILEAS Re-Banding
I don't know what, if any significance this has to scanner listeners but I saw a big sign near the METCAD (Champaign County 911 Center) building that said "ILEAS RE-BANDING" with an arrow directing people where to go.
kevino
Database Administrator
Chicagoland
Not seeing the list of application locations here, nor did I find anything on the SC21 Yahoogroup messages page.......
greeneyes965
Champaign ,ILLINOIS
ok thanks,by the way i have a pro92 and i would like to get it rebanded,i have the oraginal version which radio shack told me that the pro92 not the pro92A or the pro92B will be rebanded
RoninJoliet
ILL
None of the PRO92 models will be rebanded....They will work on Edacs Wide Trunking after you drop each freqy in your system 15mgz...The "A" and "B" models will NOT work correctly on Motorola Trunk Systems after rebanding but the one i and many others own the first model PRO92 Classic because of the way it trunks we hope will follow the rebanded Motorola systems......
Starcom21
MetroEast-St Louis
Sorry, there was a mistake in my first message.
There have been NO rebanding applications for Starcom21, except for St. Clair County T359:
851.56250
851.80000
852.16250
852.18750
852.58750
852.75000
853.63750
853.75000
851.07500
851.17500
851.22500
851.70000
852.08750
852.70000
853.13750
853.85000
Modification/Application example here:
http://wireless2.fcc.gov/UlsApp/ApplicationSearch/applMain.jsp?applID=4603952
cipher66
ARTCC DB Manager
Highland, IL
Today Scott AFB 800MHz radios that operate on the T359 simulcast system are being rebanded.... The following agencies rebanded today: Emerg Mgmt, Fire, Tower.
Starcom21
MetroEast-St Louis
T359 St Clair County - REBANDED
The St Clair County system on T359 has appeared to possibly "finished" the rebanding process.
The Control Channel is now 851.225. 866.225 is no longer a control channel
The only voice I've noted so far is 851.5625
If someone can run pro96com on this tower is would be great.
According to the license, these are the new frequencies:
2359D11 St. Clair (County Simulcast) [R]851.07500851.17500851.22500851.56250851.70000851.80000852.08750852.16250852.18750 852.58750852.70000852.75000853.13750853.63750853.75000853.85000
Old Frequencies
359D11 St. Clair (County Simulcast) 866.07500866.17500866.22500c866.56250a866.70000866.80000867.08750867.16250a867.18750 867.58750867.70000867.75000868.13750868.63750868.75000868.85000
Starcom21
MetroEast-St Louis
Pro96com
"00-0011","vi",851.07500,806.07500
"00-0035","c",851.22500,806.22500
"00-0089","a",851.56250,806.56250
"00-0127","v",851.80000,806.80000
"00-0185","av",852.16250,807.16250
"00-0253","v",852.58750,807.58750
"00-0279","v",852.75000,807.75000
"00-0341","v",853.13750,808.13750
"00-0421","v",853.63750,808.63750
"00-0455","v",853.85000,808.85000
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
301,"T0301",140,"01-2134",775.34375,"D11 - Fayetteville"
305,"T0305",140,"00-2537",866.86250,"D11 - Belleville"
306,"T0306",140,"00-2699",867.87500,"D18 - Brussels"
323,"T0317",140,"00-2617",867.36250,"D11 - East Saint Louis"
325,"T0319",140,"01-1974",774.34375,"D11 - SIUE - Edwardsville"
333,"T0321",140,"00-2549",866.93750,"D13 - Evansville"
349,"T0331",140,"00-2695",867.85000,"D11 - Sparta"
355,"T0337",140,"00-2539",866.87500,"D11 - Godfrey"
358,"T033A",140,"01-2130",775.31875,"D11 - Waterloo"
W9GC
Silent Key
Gulf Shores, AL
For what it's worth, I heard a couple ISP District 13 (DuQuoin) units today "Enroute to radio repair for code R1 rebanding".
