Starke Co.
RLD62
Indiana
I have a pro-197 and I'm hearing less and less of Starke Co. Wondering if I'm the only one.
bubbabrandon
Starke County, Indiana
I know the Sheriff's Office is on the SAFE-T system and I do hear them all the time. As for the Fire Depts and EMS they are on the conventional freqs and they don't usually have much traffic. Hope this helps.
RLD62
Indiana
Ok, I used win500 to upload I must have something set wrong. Are there any certain settings I should change? Should I have it in roam or off, anything like that would help, Still tryin to learn this thing! Thanks for the help in advance.
bubbabrandon
Looks like everything is set the way i have everything on my scanner set... The only thing i can think of is if you try moving your scanner and seeing if that helps. You have to remember Starke County is a very small county and you might not hear much at times. What Control Channels do you have it set for? I have the Winamac and Meddaryville Towers as mine. It should be set in roam since that will give you the closest tower with the best signal.
KidClerk
Newton Co., Indiana
I only recently started hearing Starke Co. and it was after I modified my settings to ID search instead of ID scan. I'm only hearing the sheriff's office on ID 44848 on the Monon tower. Still pick up fire on vhf.
bubbabrandon
That is correct the Police Departments are the only ones using the SAFE-T and they are using 44848 as their main channel. The Fire Departments and EMS are still using the conventional channels and have not swicthed over completely but they do have the SAFE-T radios installed. EMS sometimes uses 44928 to talk to one another and I have heared the Fire Departments on the Fire Dispatch only a couple times.
KD4YGG
Do you have the NEW frequencies for appropriate SAFE-T tower(s) of interest programmed in correctly?
Do you have the system set up as a REBANDED system?
chopsdotcom
knox indiana
I had my scanner programed by radioshack new a year ago. Its not just me its all scaners that i new of. Radioshack say need new codes???? Idk?? The reband programimg i do not know how to do this??? Any help would be nice! Than k you!
KD4YGG
Do you have software for programming, like WIN500?
W9NES
Indianapolis,Indiana
Radio Shack no longer programs scanners.You will have to do this yourself or have someone do this for you. There should be someone in your area that should be able to help you with this. Please let us know what model of radio shack scanners you have.This should help with finding someone in your area that has the same scanner and can help you.
KD4YGG
You will need to edit the TSYS(s) for SAFE-T that you have programmed, and drill down to the Custom Tables setting:
Enter the values below.
Lo Chan, Hi Chan, Offset, Base Freq, Step
0, 439, 0, 851.012500, 25.000
440, 559, 440, 851.025000, 25.000
560, 719, 560, 865.012500, 25.000
720, 759, 720, 866.000000, 25.000
815, 831, 815, 867.000000, 25.000
958, 958, 958, 868.975000, 25.000
961, 1022, 961, 867.425000, 25.000
HIGHLY RECOMMEND YOU DOWNLOAD A DEMO COPY OF WIN500 or PSREdit - makes this MUCH easier.
chopsdotcom
knox indiana
all freqs need to be droped by 15MHz exp-867.**** is now 852.**** this is do to nextel swaping 860.**** SAFE-T freqs with there bussness freqs of 850.****
wingmaker
You dont need all those, you can just use the first 2, and you'll be fine, but its up to you "whatever floats your boat"
Yes
LOVE AND BLESSINGS
jamesa53
IN
This.
However fast you can select a check mark is how long it will take with WIN500.
