Starrsoft
rustyjw
Does anyone else have a contact email for starrsoft? I could not find one on their website site.
Sent from my SM-G920V using Tapatalk
rustyjw
I can't get a pro2067 to take the programming. I was hoping he might have some suggestions. I've posted this issue on this forum but everything everyone has suggested haven't worked or I've already tried it.
milf
Careful, I CAN hear you!
Indianapolis, IN
Drivers updated for your PC for the cable you're using?
Checked the wiki for anything that might be causing an issue like with Windows 10, 8 etc???
Downloaded the latest version of Win92?
Made sure your Com Port settings are all cleared and set up your scanner and cable on good port?
Don wont answer e-mails unless you have an miracle! Now you can get him to reply on these forums usually if he is not too busy.
rustyjw
I downloaded Win92 within the last month.
I'm not sure about the driver. Which driver would I be looking for?
rustyjw
An aftermarket cable, don't remember the name. A guy at Radio Shack said the cable should still work. OS...Win10
milf
Indianapolis, IN
Also what systems are you trying to use the 2067 to monitor, as it is very limited now in what it can do after rebanding etc....
Use the link I posted and read up on cables, and issues with Windows 10, and other things there. Good info there!
milf
Indianapolis, IN
No problemo! Hope you get the 2067 up and running. They are still awesome on Analog Conventional , LTR TRS, the few Analog EDACS TRS out there, and the few Analog only NON rebanded Legacy Motorola 3600 BPS (Type I, II, IIi) TRS. They won't do digital at all, and won't work on 90% of Rebanded Motorola systems.
rustyjw
The frequencies I am trying to put in have all been narrow banded. Does that mean the pro2067 won't take the frequencies?
scifidad007
Newmarket Ontario
Win500
Anyone know if Starrsoft is still in biz in 2017? Ordered code for Win500 for the Pro106 and I have not heard anything at all back.
Eric
VE3EB
