Stars problem ?
greggyboy88
Rocky Mount, Virginia
Not sure whether this is a setup problem or encryption related.
I have set up various STARS through Sentinel on my 536, and have culled those locations outside my geographic location give or take. I recently learned to use analyze and when selecting STARS and all of the sites near me, analyze does not register anything doesn’t find the site at all. Was I wrong to have removed remote sites. Analyze works fine on my local system and site. ?
soccer1886
You should be able to get Fort Lewis, when you analyze you get nothing?
greggyboy88
I have run the 536 with the stock antenna fully extended. Recently I set it to 2 sections out. Seemed to help with the simulcast distortion. Analyze Fort Lewis with 2 sections and I get nothing. I went ahead and pulled the antenna all the way out and if finally did find the system. S very low. Q stays high. A of course depends. I will leave the antenna out for a while and remove the other sites that don’t register and try that for a while. Thanks.
