started my stream
rob8558
jerseycity, NJ
hey guys...just wanted to let you know i started my stream of the NJSP. i am pretty much getting most of TroopB, the parkway and Pike. stream should be up 24 hours a day depending on my internet connection...let me know if its too loud or any other suggestions.
http://winter.wavestreamer.com:9000/51591
elias1988
West Creek,NJ
It sounds great on my end, what scanner are you using :?: I'm putting Troop C on my feed when i get my Pro-2096.
rob8558
jerseycity, NJ
uniden BC296D handheld..and thnx for the replies guys. hopefully my internet doesnt go down or hiccup so i can keep it up 24/7.
jmp883
Northern NJ
Feed sounds great! We don't have a trunk-capable scanner here in our comm center so we can't monitor NJSP. Now, between the scanner and your feed I'll be able to monitor the 3 major highways that go through our jurisdiction.
Thanks again! :D
Joseph11
This stream sounds great; it doesn't rebuffer on dial-up. Would you mind posting a list of the talkgroups you have programmed?
rob8558
jerseycity, NJ
hey thnx guys...still trying to work out some kinx. as far as talkgroups go:
Troop B - North
Talkgroup Designator Use
48 B2-FW Fleetwide
35664 B2-1 Division Call – Troop B
35696 B2-2 2 Comm – Sussex County Patrols (Sussex Stations)
35728 B2-3 3 Comm – Warren County Patrols (Hope & Washington Stations)
35760 B2-4 4 Comm – Central Patrols (Netcong & Totowa-Sub Stations)
35792 B2-5 5 Comm – South Patrols (Perryville & Somerville Stations)
36656 B2-6 6 Comm – Marine Dispatch North (Newark Bay & Lake Hopatcong Stations)
35856 B2-7 Ops - Car to Car, Alternate Dispatch
35888 B2-8 Command Post, Caven Point Command (Orange Terror Alert Status)
35920 B2-9 InterOps - Car to Car, SPEN 1 Patches
35952 B2-10 Former Marine Dispatch (Moved to B2-6)
35152 B2-11 Executive Protection
36012 B2-12 Sports Complex Unit (Meadowlands Patrols)
36048 B2-13 Delaware River Joint Toll
Troop D - NJ Turnpike
27024 B2-14 3 Comm Patrols – North (Newark Station)
53264 C3-14 1 Comm Patrols – Central (Cranbury Station)
Troop E – Garden State Parkway
26928 B2-15 2 Comm Patrols – North (Bloomfield Station)
53296 C3-15 3 Comm Patrols – Central (Holmdel Station)
27088 A4/B5/C6-15 Headquarters Channel – Car to Car & Special Ops
Troop C - Central
36784 C3-10 Marine Dispatch – Central (Burlington, MCD, Ocean & Pt. Pleasant Stations)
i have every talkgroup programmed however these are the most common ones picked up.
rob8558
jerseycity, NJ
after doing some reading im curious if i am doing something wrong...any help is appreciated guys.
NEW JERSEY STATUTES (1995)
CODE OF CRIMINAL JUSTICE
RIOT, DISORDERLY CONDUCT, ETC.
2C:33-21. Use of information intercepted from police, fire or
emergency medical communications system
Any person who intercepts any message or transmission made on
or over any police, fire or emergency medical communications sys-
tem, or any person who is the recipient of information so intercepted,
and who uses the information obtained thereby to facilitate the
commission of or the attempt to commit a crime or violation of any
law of this State, or uses the same in a manner which interferes with
the discharge of police operations, shall be guilty of a crime of the
fourth degree.
L.1991, c. 432, s. 1, eff. Jan 18, 1992.
2C:33-22. Possession of radio capable of receiving transmission
from police, fire, or emergency medical communication
system
Any person who, while in the course of committing or attempting
to commit a crime, including the immediate flight therefrom, pos-
sesses or controls a radio capable of receiving any message or
transmission made on or over any police, fire or emergency medical
communications system, shall be guilty of a crime of the fourth
degree.
L.1991, c. 432, s. 2, eff. Jan 18, 1992.
elias1988
West Creek,NJ
fourth degree.
system
degree.
Don't worry about that law, you're not commiting a crime, i carry my scanner with my when i go out, i drive pass cops and walk around my town with my scannner they don't care that i have it.
KC1UA
This ain't gettin us noplace, we'll have to blast!
Marstons Mills, Cape Cod, Massachusetts
Thanks for providing the feed, it does indeed sound great.
One comment; I notice that you're providing a 40K stream. I'm not sure what your ISP allows you for upload bandwidth, but you're using a huge chunk of it depending on how many people are connected to your feed. If you're using WME9 and haven't tweaked your registry settings then only 5 people can be connected at once, which equals about 200K of upload bandwidth.
While you might lose some quality, usually these streams can be run effectively at 16-20k, which would either provide you with more upload bandwidth for personal use or would allow for you to double the amount of clients that could connect at once. You can find out how to increase your client quota in WME9 by typing "maximum connections" in the help search. It does require a registry tweak and provides pretty clear and concise instructions how to do so.
Just .02 from a long time feed provider. Nice job. Fun to listen to NJSP, I transit the state a few times a year and am always tuned in when I do.
jnl67
I am getting the following errror message in WMP when i try to connect to the stream.
"Windows Media Player cannot find the specified file. Be sure the path is typed correctly. If it is, the file does not exist at the specified location, or the computer where the file is stored is offline."
Joseph11
Go to run and paste one of the following strings:
Code:
wmplayer http://winter.wavestreamer.com:9000/51591
for WMP 7.x, 8, 9, or 10.
Code:
mplayer2 http://winter.wavestreamer.com:9000/51591
for WMP 6.x.
elias1988
West Creek,NJ
Troop C
I'm buying my Pro-2096 tonight so i'm adding Troop C to my feed, it should be up and running in the next couple of days; it anyone would like to listen look in my signature for my feed info.
Joseph11
Re: Troop C
Lucky you. You're not dedicating the PRO-2096 to your feed, are you?
rob8558
jerseycity, NJ
thank you for the insight...didnt want to lose quality of stream so i encoded at 40k, but now that you tell me i can reduce, i will when i see more users listening in. i currently have it set to 10 listeners and am running the stream on an unused computer with its own dedicated broadband connection.
i appreciate all the feedback guys.
