State of Delaware 700 MHz TRS
Newark, DE
Pro96Com's TG log displays radios registered on the system with TG's of: 128, 129, 130, 132, ,134, 136, 154, & 63270. The Patch log displayed patches of TG's 133, 135, 137, & 138. If anyone would like a copy of the logs, just send me a PM.
Audiodave1
Chadds Ford, PA
I see those groups active from today's UT log, just a single key up on each...except 63270 which had 2.
No activity on the NCC sites since 4p or so. Need to review the HP1 recordings of TG's listed in the dB.
Audiodave1
Chadds Ford, PA
Could those (with pro96com or UT) south of Newark check the CC on 769.15625. It is site #9 but I can barely touch it from north Wilm.
Need the details and nac.
Audiodave1
Chadds Ford, PA
Here's the TG's (attached png) and activity from the Wilmington site for the past 48hrs or so from Unitrunker.
Dave
de784
Delaware
Wirelessly posted (BlackBerry8530/5.0.0.973 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
System very active tonight in sussex I don't know how to work unitrunk though
hey
Lewes, Delaware
My friend thats works at SCI said the radios they have S-SCI OPS its there day to day operations throught the prison
Audiodave1
Chadds Ford, PA
Very good.
For tagging, Does/Should SCI stand for "State Correctional institute" or "Sussex Correctional institute"
Hence, NCCCI for new castle and KCI for Kent facilities?
I have yet to record someone calling NCCI or KCI, Just SCI control on TG's 110, 140, 127
Dave
pinetree
Felton DE
I have a question about the sites. Looking at both the Kent and Sussex sites there is no site close to the prisons in either county. Are there some sites not listed?
Audiodave1
Chadds Ford, PA
Ok,
So anytime I hear them calling "SCI Control" I should assume it's Sussex.
I will label as such later. Seems they are the only ones on the system at this point.
Audiodave1
Chadds Ford, PA
TG106 was being used extensively for coverage checks in various housing units (1-9) of a facility. There are coverage issues from the portables....they kept switching to talk around.
Imagine that, concrete and steel everywhere.
Also testing quick count testing TG117, 118, 146, 147.
Not sure what site(s) as I recorded on the HP1. All NCC sites were scanning.
Audiodave1
Chadds Ford, PA
Ok, time to get back to this system.
I found a new site today (see dB) and it has DOC TG 100 and 110 active on it. No idea where it is but it is in site trunking mode as it is reporting no peers.
Friends near Kent and SSX county, please have a search around and see if you have any new sites to report.
I would also like to start narrowing down which sites are carrying what TG's. Seems last time I listened / logged this system for awhile it was just SCI on it. Tough to tell who and where based on recordings with no usual PD type comms identifying streets and tows....
Also, Has anyone hears Encryption on this system yet?
Dave
scannerdel
Newark, DE
DELAWARE 700 MhZ system
Yes, it's true, DE going to 700 MHz system.... some radios are being converted this week, rest of NCCo to soon follow, then Kent, then Sussex. The radios will be able to tx and rx on both the 700mhz system and the 800mhz system until the entire state is changed over, then the 800 mhz will be "turned off" so to speak, and the 700 mhz system will be utilized exclusively.
the more things change the more they stay the same.
73's
