State of Delaware P25 Phase 2 (2025) Transition and observations
jblackst
Knoxville, TN
... and if the old and new systems are meant to reuse frequencies (like I observed at the 01-17 Hockessin site), I bet they won't leave the old one OTA very long
h8tdigitalradio
Uniden Beta Tester
Six Feet Over
Hello,
Site is OFFTA. UniTrunker does not show CCh 853.2125 in use yet as a VC on P25 Phase II System.
tvboy08721
Millsboro, De
There was a story today on WBOC about the new radio system if anyone was interested.
coopermj
Mike
Bear, DE
State of Delaware announced on their website at 12 noon today. Essentially the same article/pictures:
policefreak
Berlin, NJ
So is Wilmington FD on their own site of the TRS? No more crossover on the TAC channel on the New Castle site?
h8tdigitalradio
Uniden Beta Tester
Six Feet Over
Hello,
FYI, the CCh from NCCo Site has switched to 853.2125 MHz. 851.4875, 852.2375 and 852.7125 are now part of VCh rotation. Wilmington's Site as of now is simulcasting TGs other than City of Wilmington TGs.
WFD is still using N-TAC5. N-TAC5 does not affiliate to Wilmington's Site.
Hbright
DIVCOMM said the new system includes the integration of AES, but, last I checked, the encryption is still DES. Is that still the case?
magiclightman
I’m believe AES will be implemented down the road, they kept with DES to make the initial cutover easier. During the first few months there was some issues with interop between the dispatch consoles and systems around the encryption keys which is why PD was using IOP and MA TGs
maus92
OCMD
851.3625, 852.350, and 852.8375 are now getting channel grants on the Sussex P25 site, although those channels are still getting channel grants on/from the SmartZone system as well. These are the three remaining non-control channel frequencies provisioned on the SmartZone site. The SmartX controller will allow this, and is a sign that the shutdown of the SmartZone site is nigh.
maus92
OCMD
And as I just checked after writing the above, the new control channel for the P25 site in Sussex is 853.5875, and the SmartZone site appears to be off the air. Looks like the last channel grant on the SmartZone system was logged on Monday at 13:43.
jblackst
Knoxville, TN
Any word on the Hockessin site? I did some recon in July but both P25 and SmartZone were running together at the time. I don't anticipate being back up there before the end of the year.
trailhiker73
Delaware
Here's the minutes from the Statewide Interoperability Executive Committee meeting in September. I'm wondering if NCC TAC-5 needs to be relabeled for Wilmington Fire?
  • 81082_Minutes-Final.pdf
h8tdigitalradio
Uniden Beta Tester
Six Feet Over
Hello,
It would seem that way to change N-TAC 5 to WFD. The document stated WFD needs interops with the County. Traditionally, there was a Patch on the old P16 3600 Baud System. The Patch on the new system has not been utilized, affiliated to but no Channel Grants.
N-TAC 5 does not affiliate to the Wilmington Site. The Wilmington Site is not fully utilized, only 2 Channels out of 7 are used in TDMA Phase II Mode. Only subscribers to affiliate to Wilmington Site are WPD and Streets Public Works. Streets is not simulcasted to County, and local to Wilmington Site. There are occasional County TGs that affiliate and Channel Granted.
Btw, WPD uses WFD Tactical Channels occasionally.
maus92
OCMD
There seems to be an effort to consolidate Sussex's three EMS talk groups into one talk group. At first, they will be cross-linked (patched together), then then the radios will be touched again to eliminate them from the channel lineup. No timeline.
