Anyone able to hear anything on this system? I get nothing but silence.
Welcome to the RR forums. What scanner(s) is (are) you using to monitor? Were you able to pick up the system before? Providing specifics here on the forums goes a long way to help us help you troubleshoot. If monitoring with anything other than a Uniden SDS100 or SDS200 then simulcast distortion may be a possibility. But other possibilities may exist ranging from disabled service types to disabled quick keys or various programming errors.Anyone able to hear anything on this system? I get nothing but silence.
I'm using a Motorola APX900 on the non affiliate scan (hidden talk groups) method. works perfect for every other system in my area, but for some reason I cannot get any traffic on this system.Welcome to the RR forums. What scanner(s) is (are) you using to monitor? Were you able to pick up the system before? Providing specifics here on the forums goes a long way to help us help you troubleshoot. If monitoring with anything other than a Uniden SDS100 or SDS200 then simulcast distortion may be a possibility.
I should also add that I have tried listening from downtown Atlanta, Cobb County Area, and Cherokee County. Same ResultsWorking fine for me. Listening to HERO now.
Yeah, thanks for the suggestion, but fortunately (or maybe unfortunately lol) that is not my issue.Just something to check. Make sure the RFSS and site numbers are entered correctly, HEX vs decimal.
I assume you're using all the same settings listed on the database page right?Interesting. In that case, clearly an issue with your radio or programming.
The tower is on top of 2 Peachtree Street downtown but covers the core of the metro well. I am currently listening on a handheld indoors in central DeKalb.
What are you using for your FDMA/TDMA channel map?Yes. Working fine on my SDS100 scanner and also on my KNG2-P800 radios, programmed for RX Only (non-affiliate scan method not required since KNG radios can be programmed for true RX only, without the need to hack a system key, right from the factory).
Yep that’s what I’m using.. so weird.It's Phase II. TDMA only. Standard. 851.0125 / 12.5 / -45 / TDMA.
Can anyone hear Georgia state patrol on these channels?
